Today's Kodak Moment: Uhhhh, Beavis- will these vents work?
Steamhead
Steamhead Member Posts: 18,455
edited December 2016 in Strictly Steam
Looked at this steam system today. Someone had replaced the main vents in the not-too-distant past.............
Consulting
New England SteamWorksSolid_Fuel_Mandelta TSWEI1Matthias
    These were relatively short mains, so I installed Gorton #1s and added a riser to the one that didn't have it. It vents much more quickly now and doesn't leak steam.
    Sometimes, all you can do is shake your head and get out the wrenches.
    Consulting
  • kcopp
    kcopp Member Posts: 4,669
    Well yes that is silly... but at least they knew a vent needed to be there and didn't just plug it.
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    Those auto vents let all the air out till water reached them right..... :p
    EzzyT
    Both the air AND the steam.
    Consulting
    Solid_Fuel_ManSWEI
  • Solid_Fuel_Man
    The steam has to get out so it can heat the area right?
    That must be it... huh-huh.... huh-huh.... huh-huh >:)
    Consulting
    SWEI
