Crown 3-pass
Dan Foley
Member Posts: 1,258
Before
After. Crown 3-pass with Beckett burner. Poppy and Brian put this one in. Old farm house in Leesburg, VA1
Looks good, why the tiger loop, and why the super long flex lines?
Why the long flex lines? Because I ordered them instead of Brian. He used what was given to him.
If Brian ordered the parts, it would have been right.0 -
Nice. BIG improvement0
Nice install @Dan Foley, is the nipple/coupling/plug in the back right corner of the boiler an adaptation of the skim port for chemical additives? Also, is there another return which connects the hartford loop?0
Never mind the Hartford loop question, I reexamined the picture and figured it out looks almost like a Gifford loop.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
