Understanding Honeywell Electronic oil primary R7284B
Dmq400
Member Posts: 2
Can someone clarify for me what this digital replacement controll will do? Will it replace the 24v tstat circuit and fan relay assembly (may not be using the right terminology...sorry) on this older Unicell oil fired hot air furnace? Looked at the instructions a few times (horrible btw) and was hoping to find a bit more info on line about actual installation. Striking out. -Dan
No you need to add the ac ready kit
Thought that was only used with AC. Can you point me to a wiring ladder diagram for heat only? much thanks0
What problem are you having? If you just want the control to work you are going to have to run another wire from the service switch to the control.
To provide a wiring diagram we would need to know what other components are on your system. Fan limit switch? Fan center?There was an error rendering this rich post.
- 50 Industry Classes
