0-3 psi gauge
rmoore007ri
Member Posts: 45
WIKA does not seem to have a 0-3 psi gauge anymore. (Need to replace mine) . . . Suggestions ??
i bought this last year when my Wika started acting up -
https://www.amazon.com/Kodiak-Controls-KC25-3-Pressure-Gauge/dp/B00H9ZWLZG/ref=sr_1_1?ie=UTF8&qid=1481288868&sr=8-1&keywords=3+psi+gauge
It seems fine but it's on;y been in use for about 10 months.
3PSI gauge0 -
You can get them....theres a 2 to 3 day lead time....i just placed an order on tuesday for 20 through Valworx http://www.valworx.com/product/low-pressure-gauge-25-0-3-psi..... i now install a 1/4" ball valve below the valve to protect itASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company1 -
How does the valve below the gauge protect the gauge?0
But if you open the valve when the boiler is under pressure, and then you close it, doesn't the gauge stay pressurized? I'd think you'd need to pipe in another valve to release the pressure after you are done reading the gauge.0
You are right @Abracadabra .... i usually just shut the boiler off and let it equalize....ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
