Vent mains fast, radiators slow
ben_18
Member Posts: 70
I get vent mains fast, but why "radiators slowly"?
The largest volume of air which must be pushed out by the steam is in the pipes. The main vents, which handle this air escape must be large enough to provide as little resistance as possible. The steam will then fill all the pipes first before starting to rise to all the radiators simultaneously.
Slow radiator vents will provide a slightly higher resistance to the escaping air, and therefore the radiators will fill after the pipes.--NBC0 -
1. If you vent them too fast you can more easily overheat the space. This is about control.
2. If you vent them too quickly and have rads connected at the top and bottom they can short circuit more easily.0 -
The steam will rush to the end, skip most of the sections and close the vent. Essentially reducing output. If you vent them really fast you can equally overheat the entire house. Remember just because steam stops doesn't mean that heating stops. Those rads stay hot for a while.0
Couldn't it be the exact opposite too? Assuming you're trying to overcome a big difference in current temp vs. thermostat setting. Closing those rad vents too quick will increase chance of shortening the cycle from pressure before thermostat is satisfied.KC_Jones said:The steam will rush to the end, skip most of the sections and close the vent. Essentially reducing output. If you vent them really fast you can equally overheat the entire house.
If you short circuit and can't get the whole rad hot, you could run the risk of not heating the house. It depends on what type of radiators you have and how they react. I have steam only rads in my house so the short circuiting isn't an issue.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
