unit heater
keith_27
keith_27 Member Posts: 64
have a steam unit heater in part of building that is not getting warm at all. the unit heaters before and after this one are ok. there are hoffman f &t steam traps on all of the heaters. do they make a rebuild kit for the traps or best to replace it ?
  • BobC
    BobC Member Posts: 5,539
    Have you tested the trap? There are kits available, maybe @Sailah can direct you.
    Bob
    3PSI gauge
    EBEBRATT-Ed Member Posts: 19,583
    Yes, they do have rebuild kits. Post the pipe size (probably 3/4") and the model and someone can help you out
  • keith_27
    yep its 3/4
  • Sailah
    Sailah Member Posts: 826
    Let's see a pic probably an FT53 or FT015H as those are the most common Hoffman traps
    Peter Owens
    SteamIQ
  • keith_27
    here is a pic of the heater and trap
