I think I bought a steam generator?
I was lured by the sweet sweet siren song of a "steam generator" at a local auction but the photos weren't very good so I just sort of winged it. It wasn't throw away money but I'm not losing sleep over it either.
We used to have portable steam generators that we could take on the road and have the catch basin etc but are missing the prime mover. Which is why I bought this contraption.
I'm posting the pics in case anyone has an idea about how it works. The are various solenoids, gauges, motor, tank and lots of fittings but I can't wrap my head around how this works. @gordo video on his beautiful Hoffman had me thinking (along with the big "vacuum pump motor" sticker...) that somehow this was running a vacuum?
Anyone want to take a shot at this, I'm willing to try anything. Especially since my boss walked by it and said "What the $%& is that thing?" so I'm motivated to make it work...
Thanks!!
SteamIQ
Perhaps medical sterilizer....surgery instruments etc????
The term "Autoclave" sounds like a good term to explain to the boss.0 -
Is there some sort of Heat Exchanger inside?0
Can it just be a vacuum pump0
Yeah, we make OEM parts for sterilizer companies don't think that will work on him...JUGHNE said:Perhaps medical sterilizer....surgery instruments etc????
I'm going to find out tomorrow. There is a hook up for those compression fittings so maybe?EBEBRATT-Ed said:Is there some sort of Heat Exchanger inside?
I don't think it's even a vacuum pump can't see the pump head clearly. I think it's just a liquid pump.Leon82 said:Can it just be a vacuum pump
I think the best plan is to rip it apart and start fresh. I wonder what the best heat source would be assuming I need to run this off 120v 15a outlet? Would love to use a camp stove but I'm sure a venue like a trade show would frown on that.
Plus the pump is 2hp 3 phase and I can't run that easily without a VFD outside the plant.
Like I said, it's a problem I have haha. I should post up some of the other treasures I've dragged home. How about a 100 Ton hydraulic press...
Peter Owens
SteamIQ0 -
Isn't there some nameplate or tag on the box part of it?0
I have a steam generator for my shower and there is no motor on it.
the motor has a sticker that says vacuum pump. Maybe its part of a contraption0 -
Sounds like you like your showers as hot as my wife does.Leon82 said:I have a steam generator for my shower and there is no motor on it.
The 100 ton press comes in handy when making coal into diamonds
The waterproof hard wired whip hanging off the thing makes the think that it was mounted outside. Certainly some kinda pump for something. I'd like to say old school pool pump but I'm sure that's not right. That's the pump that goes to the thingamajig next to the whatchamacallit which plugs into the doohickey.0
Can you tell us what the black tag on the motor says? This is the tag just below the motor's nameplate.
This could be a liquid ring vacuum pump, although I haven't seen one that looks exactly like this one.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
The pump tag says:Pumpguy said:Can you tell us what the black tag on the motor says? This is the tag just below the motor's nameplate.
MTH Pumps
T41L AB
http://www.mthpumps.com/english/t41.html
Thanks!Peter Owens
SteamIQ0 -
To me, it looks like a seal circulation pump unit. It would supply a much larger pump's seal with lubrication and cooling. All it would really do is pump what is in the tank in a circle to support the larger pump. If the larger pump's process is hot then it would have a heat exchanger to cool the liquid (normally oil). This most likely explains the thermocouple and the two compression fitting on the tank.
To have it functional you'd have to make a loop from the pump discharge to the reservoir inlet. Add a flow adjustment while having to adjust the pressure controller (labeled TCV-1) to create the specific GPM and PSI. Each large pump and seal would have a specific flow rate and pressure. Then you'd hook up water to the fitting I marked to a water supply to cool the liquid in the reservoir.
I spent 5 years as an operator at an oil refinery and most large pumps have these types of units. My guess was this fed the seals on the "Vacuum Pump" or possibly cooled the bearings on the "Vacuum Pump Motor"
Mike
A regenerative turbine pump is used for low flow high pressure applications.
Looks to be a way to build lots of pressure (velocity)
https://youtube.com/watch?v=oWHY5bxQGu4
maybe this is a lethal squirt gun?0 -
Mount a siren and some flashing lights on it to impress the boss.
Interesting Mike thanks. So what you're telling me is I bought a lot of nice brass pipe fittings lol?Yourself said:To me, it looks like a seal circulation pump unit. It would supply a much larger pump's seal with lubrication and cooling. All it would really do is pump what is in the tank in a circle to support the larger pump. If the larger pump's process is hot then it would have a heat exchanger to cool the liquid (normally oil). This most likely explains the thermocouple and the two compression fitting on the tank.
Mike
Peter Owens
SteamIQ0 -
Sorry to shoot down your steam generator dreams. Don't forget you also got that nice 3 phase pump..... Fountain in the front yard anyone??? lol0
Could always part it out on Ebay.
That pump has to be worth something.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 15.6K Strictly Steam
