1920s Hoffman #2 Vacuum Steam Vent Tabletop Demonstrator
Gordo
Gordo Member Posts: 857
edited November 2016 in Strictly Steam
Restored 1920s nickle-plated brass mini boiler with glass view ports showing that Hoffman single pipe vacuum steam vents were "the watchman of the coal pile" and worth the extra cost.
https://www.youtube.com/watch?v=4ple0cVv6ow
Please subscribe and comment!
RomanGK_26986764589SailahSWEIChrisJSteve Minnich
  • BobC
    BobC Member Posts: 5,539
    Very interesting, it's a shame nobody builds something like that any more.
    Bob
    3PSI gauge
  • ChrisJ
    ChrisJ Member Posts: 17,068
    Bob
    You could if you wanted to,
    I'm sure one of these is a good and safe starting point.
    https://www.amazon.com/Jensen-Steam-Engine-Fuel-Heated/dp/B001JJAZLU
    My son will be getting one as soon as I feel he's old enough.
  • hvacfreak2
    hvacfreak2 Member Posts: 500
    Interesting , cool stuff . I remember years ago removing some vents like that and wondering what the heck that tube was for
    ( and how they got it in there ).
    hvacfreak
    Mechanical Enthusiast
    Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV's
    Easyio FG20 Controller
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Thanks, Gordo. Great stuff. I have one of their old ads where the set the water boiling violently again with a single match after the vacuum settled in. Love to see you do that.
    Retired and loving it.
    SWEIGordo
  • Gordo
    Could you post a copy of that ad, sir?
    Yes, I think I should be able to make a short video doing what you suggest very soon.
  • gerry gill
    gerry gill Member Posts: 3,083
    you are awesome Gordo! thank you so much for sharing that with us.
    gwgillplumbingandheating.com
    Gordo
  • DanHolohan
    I'm traveling, Gordo, but I pulled this from a PowerPoint slide I used in my seminar days.
    Gordo
  • gerry gill
    you know, we got nothin' on the old timers.
    Gordo
  • ChrisJ
    Sure we do.
    The problem is we're stuck with fairly old, half baked stuff rather than newer technology for steam.
    There's plenty of improvements that can be done, but instead I guess these 1960s-70s pin type boilers are fine. :/
    Gordo
  • vaporvac
    vaporvac Member Posts: 1,520
    OK, this is just about the coolest little demo I've ever seen as it illustrates the exquisite genius of vacuum steam so simply. Someone please tell me again how this fell out of favor. This would be the saviour of so many one-pipe systems. @Gordo, you must add the match and maybe show how the pressure returns to 0 once air is introduced. What a gem. Where did you ever find it?
  • ChrisJ
    In my non-professional opinion this fell out of favor and the 33% pickup factor was created all because of half-baked conversions of coal systems where guys had very little time to make things work. People found what seemed to work best on systems and just rolled with it.
    We can't blame anyone for that, but sometimes when we're bored staring at the wall perhaps we can ponder up improvements and ways to make things such as vacuum work.
    That's my opinion, and I'm unanimous in that. :)
    Hopefully, someone will know where that quote is from rather than just thinking I'm a dope.
    Gordo
  • BobC
    " I'm unanimous in that"
    I had to look it up to make sure I got the spelling right but it was Mrs Slocombe in Are you being Served
    I wonder how her **** is doing?
    https://en.wikipedia.org/wiki/Mrs._Slocombe
    3PSI gauge
    ChrisJGordo
  • JUGHNE
    JUGHNE Member Posts: 11,513
    Brit sit coms can be re-run and enjoyed almost as much as "Mash".
    BobCChrisJSWEI
  • Gordo
    @vaporvac : We found this gem on ebay some years ago.
    We are looking forward to making another video of this, using either a match or a small votive candle to boil the water when we get the vacuum down below 10" Hg.
    Would like to attach a larger 0-30" Hg gauge and get a reasonably accurate digital thermometer with remote probe to put down in the well on the demonstrator.
    We had such a thermometer ready, but it started giving questionable results as we started setting up for filming. It seemed to read about 203*F when the water was boiling at one psi.
    vaporvac
  • Gordo
    Coming from you, sir, that means a lot!
