Fiberglass Insulation Vs Asbestos
New England SteamWorks
Member Posts: 1,529
Just had a great customer borrow a $50k thermal imaging camera and train it on one of my installs. He reports that the new 1" fiberglass is 5 degrees cooler than the original asbestos insulation (which is in excellent shape by the way), and that the fittings with original mastic insulation are 30 to 40 degrees warmer than the pipes. Because of arguments here, I asked him to check the pvc/fiberglass fittings. He says he'll get back to me with a bunch of neat info on that and other stuff. I will post when I get it.
newenglandsteamworks.com
2
That is outstanding. I hope he takes some pics, as well.Two-pipe Trane vaporvacuum system; 1466 edr
Yes, he did. I've seen a preview in an instant message. Just waiting for the email and I will post.New England SteamWorks
newenglandsteamworks.com0 -
humm, my experience has been different. Ive found the 1'' asbestos cell to be better than the maying 1'' fiberglass..gwgillplumbingandheating.com
Here is some neat info:
newenglandsteamworks.com3 -
Here is a photo of the existing asbestos, which as I say, is in good shape:
Great pics, may I use them in training presentations, with credit of course?Bob "hot rod" Rohr
You can buy a FLIR camera that attaches to an iPhone for around $200. You can see all three conditions in my house below:
Background Main Pipe: Asbestos insulated pipe.
Foreground Main Pipe: Fiberglass insulated on the left side, uninsulated on the right side.
The fiberglass is cooler than the asbestos, but it's also thicker.1 -
Right, and the asbestos has probably had 60 years to degrade it's R-value.0
For now...0
- 116 Geothermal
- 169 Indoor-Air Quality
