Monitor boiler
Member Posts: 149
Hello all,
Came across this boiler today which I'm told is a Monitor MZ 225c. It is shot cycling (on/off) every minute or so.
The customer needs to reset the boiler every time he wants heat. It looks like he presses a reset button on flue pipe which I think is a limit switch.
I could not find any manual on the job or online for any help.
I attached (I hope) some pictures of the boiler and heater it is connected to. It's a single zone system with the indirect. I think it needs some additional piping but I'm not sure. Any help would be great.
Thanks.
Tor
Thanks.
Tor
wow, i thought i was the only one to ever see one of those.
French made POS. if it is the flue gas limit thats tripping its scaled up inside and out. I loved how the honeywell ignition control is a single try for ignition. one misfire and its locked out- no heat
good luck0 -
Thanks for the responce. Do you have any idea where to get a piping diagram or manual? I can access anything on line and have no clue who the local rep is.0
Dan, I think I sent you a pm, just not sure if it went through.0
Here are my notes on where to find parts for Monitor boilers, but they are from 2012 and they may no longer be available.
6/13/12 Spoke to Rob Kushner (oilman501@aol.com) and ordered parts for Pietkiewicz
Here is the place
They are really good.
Ask for Bob.
http://www.budnyfuel.com/
Trenton, NJ
1/23/12
monitor parts
you might want to contact : Nelson & Small on canco rd. in portland, me. / they are, or at least were the northern new england distributor for monitor & toyo stoves..water heaters ..etc.. / may still have parts for your need../ good luck..
For parts: Northern Heating in Wasilla Alaska has a fair parts selection. 907-376-7515
Home office: (309)361-9353
x1 - Sales
x2 - Tech. support (Nick Russo)
Dan, got it Thank you. ALan thanks for that info. Does any one know what that small rubber hose hanging is or goes to, I could not see it in the parts breakdown Dan sent.0
Looks like it's attached to the auto air vent.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
1/23/12
monitor parts
FWIW... Nelson and Small folded up shop and couple years ago.0 -
the short cycling could be related to a flow issue. Did you check the onboard pump? What type of distribution piping? Non barrier tube by chance? Could it be sludged up?
It was't a bad boiler for early condensing day. Certainly more dependable than some of the early Munches.Bob "hot rod" Rohr
Also, check that big brass strainer connected to the expansion tank by the braided hose. I've seen those clog up.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
