Fiberglass Insulation Vs Asbestos
Just had a great customer borrow a $50k thermal imaging camera and train it on one of my installs. He reports that the new 1" fiberglass is 5 degrees cooler than the original asbestos insulation (which is in excellent shape by the way), and that the fittings with original mastic insulation are 30 to 40 degrees warmer than the pipes. Because of arguments here, I asked him to check the pvc/fiberglass fittings. He says he'll get back to me with a bunch of neat info on that and other stuff. I will post when I get it.
New England SteamWorks
newenglandsteamworks.com
adamfreGregWeiss
  • vaporvac
    vaporvac Member Posts: 1,520
    That is outstanding. I hope he takes some pics, as well.
  • Yes, he did. I've seen a preview in an instant message. Just waiting for the email and I will post.
  • gerry gill
    gerry gill Member Posts: 3,084
    humm, my experience has been different. Ive found the 1'' asbestos cell to be better than the maying 1'' fiberglass..
    gwgillplumbingandheating.com
  • Here is some neat info:
    SWEIGregWeissSolid_Fuel_Man
  • Here is a photo of the existing asbestos, which as I say, is in good shape:
  • SWEI
    SWEI Member Posts: 7,342
    edited November 2016
    Ooooh, data...
    {engineer brain candy}
    Canucker
    hot_rod Member Posts: 27,472
    Great pics, may I use them in training presentations, with credit of course?
  • zackwatt
    zackwatt Member Posts: 81
    You can buy a FLIR camera that attaches to an iPhone for around $200. You can see all three conditions in my house below:
    Background Main Pipe: Asbestos insulated pipe.
    Foreground Main Pipe: Fiberglass insulated on the left side, uninsulated on the right side.
    The fiberglass is cooler than the asbestos, but it's also thicker.
    LionA29
  • SWEI
    Right, and the asbestos has probably had 60 years to degrade it's R-value.
  • zackwatt
    96 years actually! :wink:
    SWEIkcopp
  • Leon82
    Leon82 Member Posts: 681
    The fiberglass is a little cheaper to get rid of too.
    steamhouse
  • SWEI
    For now...
