Radiant floor zone - final install questions
MNMAN82
Member Posts: 3
DIY 3rd zone, in-floor heating add to a 2009 triangle tube. Cast iron radiators on zones 1 and 2, with tankless water heater as well.
Thermostat: Uponor A3100101
Zone Valve: Honeywell V8403E
Circulator: Grundfos UPS15-58FC
Switching Relay: Taco 501-4
Looking for a quick sanity check on my wiring, and if anyone has knowledge on adding a resistor (and size)?
Thermostatic mixing valves are not the best match for RFH -- ODR control works far better.
What resistor are you wondering about?0 -
Looking at this post, I guess I'll add it ...
http://forum.heatinghelp.com/discussion/138025/ideal-thermostat-for-hydronic-radiant-floor0 -
