Reccomendations: Brand Pex-al-pex & manifold for Panel Rad install
Fred Rappuhn
Member Posts: 107
I plan on eliminating some fintube and install some Buderus panel rad's with pex-al-pex, ran as home runs off from a manifold. I presently have 4 zone valves controlling the system, can I also have these zone valves serve the manifolds?
Looking for recommendations of a brand pex that has ez to use connectors and a brand of manifolds to use. I have already done a Slant fin heat loss and 1/2 pex will supply the load I need. Thoughts, please.
I like the Viega FostapexASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company1 -
What does the local plumbing store sell?
The plumbing store near me sells Apollo clamping system as well as Lowes.
The plumbing place sells slant fin pex while Lowes sells Apollo or another brand.
Both sell the Apollo crimp tool. I would not use the sharkbite style because it is probably cheaper to use copper after you spend the money for the fittings.
If you can plan your layout you can get it from supplyhouse.com. some may have a proprietary locking system, think upnor may be this way.0 -
347-692-4777
ASMHVACNYC.COM
When it comes to manifolds I am lost!!! So many choices, An 8 branch would serve my largest zone, recommendations???0
Why the dislike for my post above? Something against Uponor? Inadvertent hit?Steve Minnich0
As a landlord, we have used thousand's of feet of Viega Fostapex. We love it. We use it for potable hot , potable cold and heating applications. This is because we think its a better product than regular pex for potable(UV degradation, and stiffness for when we pull in wall and cannot support as much as we'd like) and because we only stock 2 products : 1/2 and 3/4 fostapex.
I have used it since Viega was in Bedford, Ma, which I think was 1997 ish....
I even have the original tools which were smaller(and did not have the same linkage for leverage) then the current ones, I keep the original 1/2" tool in my "jack of all trades" tool bag but have never used it....which means we never did an emergency repair on any viega pex that we installed.2 -
If the manufacturer of the pex you use also makes manifolds, I would use their manifold also0
@Stephen Minnich I don't think that's a "Dislike" For some reason the "Thanks" button changed to "Dislike" and all Thank you's to Dislikes. I sent @Erin Holohan Haskell a message. I'm sure she will get it resolved.Stephen Minnich said:Why the dislike for my post above? Something against Uponor? Inadvertent hit?
If you click it again it will take it off, at least on my phone it does. Have accidentally swiped a few while scrolling0
Thanks for the heads up on the Dislike/Thank button. Our developers at Vanilla re-purposed the Dislike button to create a Thanks button for us. A recent update may have messed with the settings. I've disabled it for now and will look into it.
President
HeatingHelp.com0
