Warranty... to rebuild or not
danitheplumber
Member Posts: 98
Have a customer who has a hole in his oil steam boiler it's less then 10 years old so he can get a new block or just new boiler with a credit toward the new one. Has anyone ever been this situation and taken an old boiler apart to put all the old working parts jacket etc. on to a new block and how long did it take. Originally he was interested in changing to gas back in the summer but now that he realizes he has only until Nov 7 to get warranty he's not interested. Any suggestions or advice would be greatly appreciated.
What boiler is it?
Burnham V8?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Yup how'd u know0
If they will give you a good credit towards Megasteam I'd think about doing that. The V8's have their problems I don't think I'd go that route.
3PSI gauge0 -
Ya they only give mega block now0
Keep in mind the Megasteam is not certified for use with gas so if they go that route, it's likely they will continue to use oil for a long time. Great boiler though.0
If you can get the warranty from them that's amazing considering the stories I've read on here.
I would not replace the block, chances are it's going to fail again. Go with a Megasteam or an Independence boiler if they definitely want gas.
Personally I'd go with gas no question.
Some guys here have put gas guns in Megasteams, but Burnham won't back it. @Steamhead could give far better details on the risks involved.
The only unknown is why Burnham refuses to certify it for gas. It may also be a liability for any installer who puts a gas gun on it, should something go wrong, down the line.0
I think the reason is political rather than technical.
But if Tim McElwain can convert boilers whose manufacturers are out of business and not have an issue, we can convert MegaSteams.All Steamed Up, Inc.
Consulting0 -
So its safe to say it's not done0
I wouldn't. The liability lies on the contractor from that point.0
- 167 Indoor-Air Quality
