new navien
Snowmelt
Member Posts: 1,428
here are three pics, there are a few things wrong or should I say not perfect
customer has to decide if he wants a 007 E or a Viridian.
the shut off on pump isnt straight
2
nice install @Snowmelt .... sometimes you have to spin the motor to fit the webstone iso flanges rightASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Thanks0
Nice install @Snowmelt. The PVC is on the air intake what did you use on the flue exhaust?0
they have a return loop on domestic that's existing, what kind of pump would you use for domestic water would you use a taco smart plus or a taco or the genie ? I used cpvc , kinda on the expensive side but it is what is needed0
just out of curiosity what do you guys think of using a 3inch pvc coupling on the bottom of the expansion tank to take the weight off the pipe?0
I use a bracket to hold the expansion tank .... i posted a pic of the one ive been using.... theres also the hydroclaw expansion tank holder ive seen people use .... its a little bit more pricey than the one i use.... i also seen people use a large "U" bolt connected to some strut....
347-692-4777
ASMHVACNYC.COM
- 86.8K THE MAIN WALL
- 56 Biomass
- 107 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
