Bryant T6 PRH01 to control heat (boiler)?
FredCapo
Member Posts: 21
Can I use my Bryant T6 PRH01 thermostat (installed for my separate 2 stage central air conditioner) to control one zone of my Weil McLain gas boiler? The current heating thermostat for the zone is in same location as the T6. Thanks
Yes, follow the instructions to separate RC & RH terminals. The boiler will use RH and W, the A/C would use RC, Y1, Y2 and likely common. May have to do something in an advanced setup menu in the stat.
Only issue would be is if you have a White-Rodgers 3 wire zone valve.0
- 50 Industry Classes
