PV to electrify old iron
I installed a 12VDC, 200 watt element into this old radiator and filled with water. A couple 120W PV modules for power.
This element has a temperature control built on, goes up to 190F! Apparently they get used for off grid brewing applications.
I'll roll the rad into the shop, around 65F today and see how it performs.
I'm starting a tiny home project and adding some radiators, or panel rads might work into the plan. With some PV on top, the 12VDC rads could be a dump circuit, or off grid heat and power.
How long is the element?0
6"
I have the timeHatterasguy said:Interesting concept.
However, with 680 BTUH available, it's going to take forever to heat all that cast iron to the point where it can actually deliver a few tidbits of warmth.
You need a lot of energy to warm up a heavy CI rad
Consider installing it in a very tiny panel rad.
I have a couple low mass copper radiators I built with 120V elements, just trying to put a RE spin on it.
It may well be too much mass, and weight for a tiny home project, some clever wall panels may be in the future.
Living the hydronic dream1 -
I get that it might take a long time for this to be an issue, but what provision did you make for expansion and relieving excess pressure?All Steamed Up, Inc.
Consulting0 -
I just left the top vent plug out, filled it 1/2 way. I don't know that I would ever run it with and element, I have a boiler and solar thermal to connect to it.Steamhead said:I get that it might take a long time for this to be an issue, but what provision did you make for expansion and relieving excess pressure?
Just tinkering with the PV and DC element, seeing how much heat I could pull from the sun with a wire.
Hatterasguy said:
That's a beauty.hot rod said:
I have the time
I think I put a 150W, 120V element into this one, it goes into the bottom in the copper closet flange. About a quart of mineral oil in it. The copper conducts the heat nicely and the setpoint control keeps it all regulated. It's rarely gets plugged in, more of a conversation piece and office decoration.
Can you put one or two of the elements in that one?Bob "hot rod" Rohr
It would be quite interesting to compare this simple DC resistance heater with the panels, and solar thermal like evacuated tubes or flat panel. Cost of total system, to heat output. Set similar systems side by side in the sun and see what happens btu wise....
TaylorServing Northern Maine HVAC & Controls. I burn wood, it smells good!0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
