This steam TRV?
hot_rod
hot_rod Member Posts: 27,129
has anyone use this valve? It seems like a simple way to add control to single pipe steam rads. Clicked on the Oventrop banner ad along side.
  • EzzyT
    EzzyT Member Posts: 1,379
    edited September 2016
    I've had cliente add them to there own systems themselves and from the feed back I've gotten they said they work great
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
  • EzzyT
    Works perfectly with a 2 stage firing set up
    201-887-8856
  • Paul48
    Paul48 Member Posts: 4,469
    What makes them any different than any thermostatic radiator vent?
    Steamhead Member Posts: 18,334
    Danfoss has had a similar model for years.
    Consulting
  • Paul48
    I wonder if you have to buy a separate vacuum breaker, like the Honeywell ones?
