This steam TRV?
hot_rod
Member Posts: 24,693
has anyone use this valve? It seems like a simple way to add control to single pipe steam rads. Clicked on the Oventrop banner ad along side.
I've had cliente add them to there own systems themselves and from the feed back I've gotten they said they work great0
Works perfectly with a 2 stage firing set up0
What makes them any different than any thermostatic radiator vent?0
Danfoss has had a similar model for years.All Steamed Up, Inc.
Consulting0 -
I wonder if you have to buy a separate vacuum breaker, like the Honeywell ones?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 947 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
