Water dripping off the coil?
Jim Pompetti
Member Posts: 552
We have a old carrriereat pump with water walling off the coil . The charge is good ,filter clean and the coil clear . Ant suggestions ?
Disable the indoor fan motor and allow the outdoor unit to run. The condensate will freeze and the expanding ice will scrub the fin surfaces as clean as new. Kidding , lol.
Make sure that the return grilles are not obstructed or dirty. Also make sure that the filter type is not radically different than what was in there before. High efficiency pleated filters are great if the system is designed for them but if they are too small for the application they can cause problems like this. Try the lighter duty filter and change it more often.
hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
- 123 Chimneys & Flues
