main vents
Paul S_3
Member Posts: 1,261
i have a job coming up with (2) 2.5" mains about 80ft long each....with about 900 sq ft of EDR attached to each at total around 1800 for the whole building.....i would usually use several Gorton 2's
...but i have seen some of you guys use traps and i believe ive seen someone use a f & t for this .....do they perform better...?....any recommendations? thanks Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
Why not try a couple of big mouth vents. Each of those mains has about 4cuft of air in it so one or two of the bigmouth should do quite nicely.
bobSmith G8-3 with EZ Gas @ 90,000 BTU, Single pipe steam
3PSI gauge0 -
Have you considered the Barnes and Jones Big Mouth? Each one is equal to about two Gorton #2's.
https://www.amazon.com/Barnes-Jones-Big-Mouth-Vent/dp/B01F26P13C/ref=sr_1_1?ie=UTF8&qid=1472688688&sr=8-1&keywords=Big+Mouth+vent0 -
@Fred they say currently unavailable....where would i purchase themASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
@Sailah i need what would equal 12 #2's PM me i need them within next week...ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
I believe that would be around 6 Big Mouths.Paul S said:@Sailah i need what would equal 12 #2's PM me i need them within next week...
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
thanks guys.....ill be purchasing 6 big mouths for mains....and 4 vari vents for risers.....i spoke to Peter this afternoon.ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
@Sailah Looks like it's pretty safe to say you've got a winner, eh?
I still need to install the ported Big Mouth you sent me. I'll get it in before the season, just been busy.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
@ChrisJ I'm not making a down payment on that new Maserati just yet I think the real test will be this heating season, and the next, and the next...It's one thing to make a shiny new product but my benchmark for the pros will be:
After seeing it in action at your customers homes, would you install one in your own home?
It's very humbling to have professionals put down their money to buy your new product. I truly hope it exceeds expectations.
And remember, you have the only ported Big Mouth on the planet and I'm never making another...Peter Owens
SteamIQ0 -
I just got my 1st order from Barnes and Jones.....these are beautiful vents ......if they work half as good as they look ....ill never use another Gorton....i really like the vari-vent with the adjustable screw. and there smaller too
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company3 -
I see you have your 5 footer ready for the 6" header1
yes....im going to deliver the material tomorrow morning...6 in are big and heavy fittings especially the tees
....i had to buy another one....like you said the 36 in chain may be too smallASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
You won't be needing to go to the gym after working with those babies3
Thanks Paul!
Please don't use that pipe wrench on the vents...
BTW the set screw is 5/64" allen if I remember off the top of my head because I put it in there...Peter Owens
SteamIQ0 -
thanks for everything Peter its been a pleasureASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
