Preventing Condensation in Venting
Stokehold
Stokehold Member Posts: 43
If a 3" PVC vent for a high efficiency power vented water heater or furnace must travel through the unconditioned space of a home (attic), what is the recommended type of insulation to wrap the pipe to minimize condensation? Is it better to use a foil backed foam wrap, fiberglass or pre slit foam sections?
  • NY_Rob
    NY_Rob Member Posts: 1,370
    Is it a condensing appliance?
    Check with the manufacturers install guidelines, but my condensing boiler install manual was pretty clear on PVC vent insulation:
    "DO NOT thermally insulate the exhaust vent or intake pipes. "
  • ChrisJ
    ChrisJ Member Posts: 17,070
    I had looked into this for my dad as when it's -20F out the fresh air intake sweats like you would've believe. I believe the instructions to his recommended insulating the intake.
    What does the manufacturer of your boiler want someone to do under these conditions, just let it drip all over?
