Barometric damper
STEAM DOCTOR
Member Posts: 2,566
i love the steam piping....its a shame....i see far too many installations similar to this one by us in nyc....then someone comes and rips it out to install a forced air system....ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Not the first time I've seen a baro installed like that, but it's not a great location. I'd put a smokepipe cap there as a cleanout, and put the baro in the usual place.All Steamed Up, Inc.
Consulting0 -
So much for "as close to the appliance as possible".
I was in the house for something else. Didn't mention to the homeowner. You need to know your customers. This particular customer is the "it's worked fine for many years" type of customer.
@Paul S. Correct on the steam piping. They have the equalizer function of the header without the drain function of the header.1 -
Tell them they are heating the outside rather than the water. That usually works. Leave that one as a base clean out, install a Tee and draft regulator0
Tell them to clean out around the boiler also! Storage is always at a premium, no?
Looks like most of the ones I have to deal with. Never enough room around it to work on it.
Rick0 -
The T&P on the water heater could seriously hurt someone too.
It's clear some really skilled individual does most of her work.
Yeah, the "it works fine" person who basically calls you a liar when you tell them it could work a lot better or safer.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 116 Geothermal
- 169 Indoor-Air Quality
