fostapex
Paul S_3
Paul S_3 Member Posts: 1,291
have any of you guys used this kind of pex....my supplier sells it....im using it for the 1st time for a radiator home run system ....30 rads in all...i bought all the press heads and fittings....any advice or tips.thanks
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
    hot_rod Member Posts: 26,594
    One of my favorite tubes. Put the stripper tool in a cordless drill, it's faster and leaves a cleaner end.
    In some cases the straight 20 footers work better for mechanic room piping, etc, especially in the larger diameters.
    Short cut off make nice wind chimes :)
    Paul S_3
  • Bob Bona_4
    What Bob said. You may never go back to copper.
    Paul S_3
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    @Paul S - new boiler too? The one I just finished, I installed manifolds with flow meters and valves so I could dial in the gpm for each radiator.
    Steve Minnich
  • Paul S_3
    @Stephen Minnich boiler is new...installed by another company....im repiping it....contractor installed radiators in a series loop with 1/2 pex....all 3 floors....im installing homeruns from each radiator to manifolds...manifolds are 1in CU by 1/2 pex with valves....no flow meters....each rad doesnt need more than .8 gpm in my calculations....i get good results on resi systems like this....i guess im going to start to use manifolds with flow meters what manifolds do you use?
    347-692-4777
    ASMHVACNYC.COM
    Steve Minnich
  • Steve Minnich
    edited August 2016
    I used Watts on this last one and I like Rehau too.
    Steve Minnich
