System design advice
RomanP
Member Posts: 102
Hello, gents.
I'm trying to configure the best possible system design. Client wants to have: hot water, radiant floors(tiled areas) and HVAC units with hydronic coils. I will definitely use high efficiency, condensing equipment for hot water and radiant floors. My question is: should I dedicate a non-condensing boiler to constantly feed hydronic coils with 180-190 degree water. Or, will those hydronic coils perform just fine with a condensing system with an outdoor reset? ( supply temperature will adjust accordingly to outdoor temperature)
Thanks in advance!
Thanks in advance!
Well first you need a room by room heat loss. That will tell you size of boiler, what you need for water temperatures, radiant loops, etc., and how to set your ODR curve.
Why not do the whole house with radiant? Either floors and/or ceilings.
You're running ducts too? Run air handlers/heat pumps (depending on climate) for back-up/shoulder seasons. It's not much to upgrade for AC to heat pump.
Then you can have your mod/con boiler with an indirect and a great comfortable system.There was an error rendering this rich post.
