Donating an oil tank, and oil fired water heater
zepfan
Member Posts: 436
I am in the process of doing an oil to gas conversion in which there will be a fairly new water heater, and an above ground oil tank that will no longer be needed. Does anyone know of any agencies that will pick these up as a donations. It would be ashamed to take them to the junk yard if someone can use them. Thanks to all
Try Habitat for Humanity.All Steamed Up, Inc.
Consulting0 -
Craigslist.0
??0
Your location would be key to knowing.
I may end up looking for donations that would be tax deductible if near future plans work out.0 -
Thanks for the responses. The WH and oil tank are located in Montgomery county, Maryland.About 15 miles north of Washington, DC.0
Consulting1 -
Do you still have the water heater? What model is it?All Steamed Up, Inc.
Consulting0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
