Donating an oil tank, and oil fired water heater
zepfan
zepfan Member Posts: 444
I am in the process of doing an oil to gas conversion in which there will be a fairly new water heater, and an above ground oil tank that will no longer be needed. Does anyone know of any agencies that will pick these up as a donations. It would be ashamed to take them to the junk yard if someone can use them. Thanks to all
    Steamhead Member Posts: 18,205
    Try Habitat for Humanity.
    Consulting
  • kcopp
    kcopp Member Posts: 4,630
    Craigslist.
  • ChrisJ
    ChrisJ Member Posts: 17,070
  • GreenGene
    GreenGene Member Posts: 290
  • GreenGene
    Your location would be key to knowing.
    I may end up looking for donations that would be tax deductible if near future plans work out.
  • zepfan
    Thanks for the responses. The WH and oil tank are located in Montgomery county, Maryland.About 15 miles north of Washington, DC.
    Try "Community Forklift":
    http://communityforklift.org/
    Consulting
    SWEI
    Do you still have the water heater? What model is it?
    Consulting
