Very Nice Cast Iron Radiators - Central NJ
shane_
Member Posts: 4
07/08/2016 edit: I decided not to scrap these and they are very for sale.
I have four cast iron radiators I'm looking to get rid of ASAP.
They are located ground level in a storage unit on Route 35 in Eatontown, NJ (very convenient to the Parkway and Route 18 in Monmouth County).
Dimensions (two are the exact same size):
39"H x 39"W x 9.5"D
39"H x 31"W x 9.5"D
39"H x 31"W x 9.5"D
39"H x 27"W x 9.5"D
The largest radiator is about 450-500 pounds so I'd recommend two really good men and a liftgate.
Please let me know if you have any questions or would like more pictures.
Thanks.
Shane
39"H x 39"W x 9.5"D
39"H x 31"W x 9.5"D
39"H x 31"W x 9.5"D
39"H x 27"W x 9.5"D
Thanks.
Shane
The fancy ones are Rococo rads, made by American Radiator Co. The rods holding the tops of the sections were omitted on later models, I'd put those around 1900 or so.
Let me guess- you put in a heat pump...............All Steamed Up, Inc.
Consulting1 -
are you selling them? or your just giving them away?ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
You're gonna miss those radiators, the comfort level will go way down...To learn more about this professional, click here to visit their ad in Find A Contractor.0
Thank you for the identification.Steamhead said:The fancy ones are Rococo rads, made by American Radiator Co. The rods holding the tops of the sections were omitted on later models, I'd put those around 1900 or so.
These radiators are coming out of a Jersey Shore church that got hit hard by Sandy. Between the dwindling numbers of churchgoers and the constant threat of flooding, the priority is a heating solution that works. Anything installed in the basement is no longer feasible.
So, yeah, elevated heat pump with help from electric baseboard in Februarys.0 -
I've decided to keep these to sell.
OP updated.0
