Need an advice
RomanP
Member Posts: 102
Hello, gents
I've been reading this awesome site, on and off, for quite a while and have learned a great deal here. I am huge fan of your work, Dan! Now with the a** kissing out of the way, I'd like to get to the point.
Which books can you suggest getting. I'd like to take my steam system knowledge to the next level( single pipe, two-pipe, vacuum, high-pressure) also reading more about hot water systems wouldn't hurt.
Thanks in advance
Thanks in advance
Three that come to mind:
http://astore.amazon.com/heatinghelp-20/detail/0996477241
http://astore.amazon.com/heatinghelp-20/detail/0615561071
http://astore.amazon.com/heatinghelp-20/detail/09743960528.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab3 -
And this one too:
http://astore.amazon.com/heatinghelp-20/detail/0996477233/187-2147271-3871927
I'll admit I have a particularly soft spot for SWEI's suggestion thoughAll Steamed Up, Inc.
Consulting1 -
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment1
Thanks a lot, guys! I really appreciate it0
One more question. Is there a place to share images on this site? Thx0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
