Electric impact wrench
Thanks.
I got the Makita 1/2" drive impact gun 18v. It's done very well on old chiller barrel / condenser barrel nuts.
I tried it out on a hoffman 17c, 1-3/8 socket, back-up wrench on the trap, worked like a charm.
I bought this plug impact socket set, i'm going to try it out soon on some boiler plugs for the low water cut-out clean-outs on a cast iron boiler. I'll let you know how it worked out.
It may be excessive but I brought a 4' pipe wrench and PB blaster to the party and the fittings are coming out in 5-10 minutes, tops.
I feel bad for not setting Tim up with the right tools.Steve Minnich0 -
Impact will do a lot, but finding the socket to fit correctly could be a hunt. I was so impressed with my 1/2" 18V Milwak that I rounded up all the 8 point sockets, (some impact rated) that were available. Those square headed plugs would want to break off the edges with a pipe wrench, so this has been a blessing.
This also saves the arm when punching out KO for electric work.
Even the 1/4" 18 V impact driver has walked out electric water heater elements. Takes some adaptors though.0 -
It worked like a charm, but the impact plug set I bought only went up to 3/4". So it popped off the 1/2 and 3/4" plugs that were installed with X-pando!
I put a 18" pipe wrench on the fittings, then pulled the trigger.
When I got to the 1" plugs, I used 2, 5# sledge hammers, banged the fitting from both sides a few times, then used my 18" crescent wrench with back-up wrench and gave it a quick pop. The slow motion stuff tends to round off the heads IMO.
I also used the Impact on steam traps, this has worked like a charm. Back-up wrench on the trap body, impact has popped every lid off so far.0 -
Like I've said before, impact is weird.
It often removes stuff you'd otherwise break.
For example, removing the chime rods from a clock that have brass heads will just split if you try to use a screw driver, but a manual impact driver will remove them with zero damage.
A manual impact driver and hammer will remove screws with totally stripped heads.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
It builds character SteveStephen Minnich said:It may be excessive but I brought a 4' pipe wrench and PB blaster to the party and the fittings are coming out in 5-10 minutes, tops.
I feel bad for not setting Tim up with the right tools.We ALL have to start in the bottom of the ditch. He'll remember this moving forward, and I guarantee he will need it someplace in his life. One of life's lessons on how to get the impossible done.
Back in the day (never thought I'd be saying something like THAT), I'd lay the radiators on their side for stability, then put a 24" wrench on the spud, then add a 36" aluminum cheater pipe to the mix, then place a large foam pad between the cheater handle and the floor (actually laid radiator on large piece of plywood to avoid damage), then JUMP on the cheater bar and break them babies loose with a SNAP. I called it shock and awe snap torque.
But that was when I was younger and dumber and a whole lot stronger and agile than I am now.
Now, working smarter and not harder, I think your idea of an impact wrench should work quite well, with a lot less exposure to injury.
ME
2 -
Cannot even imagine you with both feet off the floor Mark . Me either for that matter anymore .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Not a pretty sight eh... I was svelt, at ONE point in time... Then I built a roof over my tool shed.Rich said:Cannot even imagine you with both feet off the floor Mark . Me either for that matter anymore .
Beer built that house.
ME
I have found that for cheater pipes that electrical EMT pipe (thinwall conduit) works good for me. 1 1/4" or 1 1/2"
A 3' length has not bent yet. It is light and the ends can be egg shaped with sledge. The egg shape is "tuned" to stick about half way on the wrench handle by friction. The cheater stays in place and you can even pick the 3' iron one up by the end of cheater. The cheater stays on the wrench until it goes back into the truck. When done a little hammering gets them unstuck from the pipe wrench. FWIW1 -
Got the 1/2" version, challenge is finding sockets to fit a large hex bushing.0
So far -13 125 year old plugs and 13 125 year old radiator valves removed in 3 hours. Chased all the threads with an 1 1/2" tap. Radiators definitely need a thorough a flushing and cleaning.Steve Minnich0
You have an 1 1/2" tap!?
There's a sign of a real professional.
The guy I hired back in 2011 told me he had to replace a radiator because the 1/8" vent tapping was stripped. He couldn't even be bothered to carry an 1/8" or 1/4" tap.
1 1/2".......... The cost of that hurts just thinking about it.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
ChrisJ; no problem with the sockets fitting the impact driver.....I mean finding a socket to fix hex head piping bushings. Just measured a 2 X 1 1/4" hex bushing....just over 2.5" across flats on one side....across another set of flats was just 2.5". Often some irregular wrench sized fittings....wrench too small or next size too loose.
But we can all rejoice for Stephen getting out the plugs (and only the plugs...not part of a section). Good Job!1 -
Ahhh I'm sorry I misread that.JUGHNE said:ChrisJ; no problem with the sockets fitting the impact driver.....I mean finding a socket to fix hex head piping bushings. Just measured a 2 X 1 1/4" hex bushing....just over 2.5" across flats on one side....across another set of flats was just 2.5". Often some irregular wrench sized fittings....wrench too small or next size too loose.
Correction - the Powers that be just told me the radiators were installed around 1925.Steve Minnich0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
