Second hand plumbing store
ttekushan_3
ttekushan_3 Member Posts: 964
I came across this while doing serious steam heating research :-) and thought some of you might like it.
"December 1940. Secondhand plumbing store, Brockton, Mass." 35mm Kodachrome transparency by Jack Delano. View full size. As of 2007, Saba Mechanical Plumbing & Heating is still in business in Brockton, at an address on Linus Avenue."
http://www.shorpy.com/node/61
Terry T
SWEI
  • BobC
    BobC Member Posts: 5,539
    back in the day we would go to Duanes Wrecking Yard on the southern artery for heavy timbers, doors, and just about anything else you would get by tearing houses down. They also had old stoves and radiators for next to nothing.
    Bob
    3PSI gauge
  • Sal Santamaura
    Sal Santamaura Member Posts: 544
    ttekushan said:
    ...35mm Kodachrome transparency...
    Ain't nothin' like Kodachrome. Other than digital snapshots, I've only shot black and white since Kodachrome 25 was discontinued in 2001. Sigh.
  • SWEI
    SWEI Member Posts: 7,348
    I found a box of prepaid Kodachrome mailers the other day. Sigh...
