Rinnai E-110c Error code 14
BillAllen
Member Posts: 103
Customer getting this code and I don't service these but I did install it 11/2 years ago. Seems it a flow sensor but do not know what is causing it. Any ideas?
You can read the resistance across the sensor. Should be 12kOhms at 77*. Reverse acting, 7200 @ 100* & 23000 @ 50. If you remove the sensor and kinda toggle it back and forth it may free up and operate...for a while, but I'd have another sensor on the way.0
Yea I figured that. Have installed many of these and this is my first problem with the E110C. THANKS FOR THE CLUE.0
Look for the new one. It will have the variable speed pump0
Will the 50k model include a variable speed pump?0
I've only installed one E50C and other than a few shortcomings (poor documentation, connections too close together and a 3" flue), I have been happy with it. It fits nicely in with my small boiler arsenal.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
