short fat radiator, can't figure EDR
BTU
BTU Member Posts: 14
this is for a steam system, I measured ~17" high, ~13" wide, and as you can see in the pic it's 5 tubes with 10 sections. Kind of a hoss from other radiators I've seen. Does someone have an archived cut sheet for this bulldog?
side note, see the asbestos insulation on the gas line. Maybe someone was worried it would condense if it got too cold?
    Steamhead Member Posts: 17,894
    edited May 2016
    That's a Triton window radiator, made by U.S. Radiator Co. 4.75 square feet per section, for a total of 47.5. This is probably in Dan's book "E.D.R.".
    BTW, the air vent is installed in the wrong place. Looks like there is a boss low on the center column that was meant for a steam air vent.
    Consulting
    BTU
  • SWEI
    SWEI Member Posts: 7,348
    That near boiler piping...
    BTUKC_Jones
  • BTU
    thanks yall. Yeah it probably used to be a much bigger boiler from the looks of the piping
    TRITON:
    noun, Physics.
    1. a positively-charged particle consisting of a proton and two neutrons, equivalent to the nucleus of an atom of tritium.
    TRITON:
    noun
    1. Classical Mythology. a son of Poseidon and Amphitrite, represented as having the head and trunk of a man and the tail of a fish, and as using a conch-shell trumpet.
    2. Astronomy. a moon of Neptune.
    3. (lowercase) any of various marine gastropods of the family Cymatiidae, having a large, spiral, often beautifully colored shell.
    4. (lowercase) the shell of a triton.
    Wouldn't be the first time we've seen the results of an install crew who doesn't bother to read the instructions........ :s
    Consulting
