Images from the field.
Member Posts: 4,152
You never know what's in store for you.
Wow! That dates back to the 1950s at least. Where did you find it?All Steamed Up, Inc.
Consulting0 -
That is a beautiful thing and would look awesome in my little museumSteve Minnich0
Boiler room in an apartment building in Oakland. The old boiler is long gone and an A.O.Smith Burkay sits in its place.
I'm sure the Modutrol isn't hooked up anymore since the Modutrol motors are gone. It looks as though there's two spaces for vacuum tubes and those two dials are geared together; you move one and the other one moves.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Right- they were still using vacuum tubes then. Some of the original Honeywell and (I believe) Fireye flame safeguard controls did too.
See if they'll llet you salvage it.All Steamed Up, Inc.
Consulting0 -
What's your address?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Sent you a PM.All Steamed Up, Inc.
Consulting0
- 85.9K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 79 Chimneys & Flues
- 5.3K Gas Heating
- 94 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 886 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.6K Strictly Steam
- 51 Water Quality
- 41 Industry Classes
- 17 Recall Announcements
