Throwback
Tinman
Member Posts: 2,808
A throwback Milwaukee Sawzall.
It works well but I doubt I'll ever use it.
Looks great on a shelf though.
Steve Minnich
6
Built to last 50's?0
Looks like 50's my grandfather still has all his tools from that time....all the power tools were silver colored Milwaukee and black and decker he hasASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Classic!0
I'll walk for hours at flea markets looking for these gems. They have to be great deals because I won't spend much on a tool I don't intend to bring to a job site. I also saw what had to be a 50 year old Skilsaw circ saw in great condition with its original steel box. I delayed though in buying it as soon as I saw it. Circled back an hour or so later and it was gone.Steve Minnich0
Nice!........Even back then, they weren't cheap tools. The difference between then and now ,is, you could drive the truck over that, pick it up and keep working.0
And it wasn't made in China.........
SFMServing Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Yes, I remember those from 45 years ago when I started in the trade. Only toke 5 minutes of fumbling with the allen wrench to change the blade then after a few cuts the dam thing was to hot to hold with out heavy gloves. Not everything is great because it is old. I'll take the modern version anytime.1
One of my early jobs was as a mechanic repairing tools for Bosch back in the early 2000s.
The newer tools out perform and generally out last the older ones, metal housings or not.
Guys can sit back and think their 1950s-60s drills without variable speed, no clutch and no reverse are great, but really they kind of stink. They're not built that great either. I know, that's a saw not a drill, but I'm using drills as an example.
I rebuilt a 1960s 3/4" Skil drill for my uncle that was forward only and I think 400 rpm if I'm remembering right. It's a beast of a drill, but without variable speed, reverse or a clutch it's also a very limited tool and fairly dangerous. A modern rotohammer would give it a run for it's money and also hammers to boot.
Yes, they have nice heavy aluminum housings, I guess that's good if you like holding a heavy tool all day.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment2 -
You knocked your two front teeth out and simply spit them out and kept going?Stephen Minnich said:In the mid 80's, I had a metal cased right angle drill without a clutch knock my two front teeth out. I was working on a ladder and my arm wasn't braced properly. Spit'em out and kept working.
That's your story is it?Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
It is. : ). 3 witnesses and 2 new Chiclets in my mouth. What else could I do? The extraction was quick and easy. I stopped the bleeding before I got back on the ladder. I didn't want to mess up the lady's house.Steve Minnich0
The appreciation for the old tools is not because they were necessarily better than what's available now. They bring back memories of the tools our fathers and grandfathers worked with plying their trade. It's the same appreciation as the old 63 Chryslers with the push-button tranny, that Pops use to take us on Sunday drives in. Days gone by2
That's fine, and understandable.Paul48 said:The appreciation for the old tools is not because they were necessarily better than what's available now. They bring back memories of the tools our fathers and grandfathers worked with plying their trade. It's the same appreciation as the old 63 Chryslers with the push-button tranny, that Pops use to take us on Sunday drives in. Days gone by
But many go into the "they don't build them like this anymore, cheap plastic bla bla bla bla" rants.
Do you ride an AMF Harley, by chance?.0
No,Paul48 said:Do you ride an AMF Harley, by chance?.
Last thing I had even remotely similar was a highly modified Yamaha Raptor 660.
And that wasn't a unreliable leaky motorcycle.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment1 -
I was up on a ladder boring a 4" hole into an attic at a buddies son's house with a 1950's single speed Milwaukee drill (350rpm), using a 1" dowel through the D handle to brace it. About halfway through the old shingles the blade caught my t shirt and tore it right off my back - damn good thing it was a t shirt and not a jacket.
I've seen a few guys break their wrists with drills like that. When something is geared down that much you have to respect the torque it has.
3PSI gauge1 -
I have my dad's early 50's Craftsman circular saw. It is really good shape but I have to agree, the RPM is so slow and the saw is so heavy that it just isn't practical to use today, although he used it and, as a kid, I don't recall him having any issues using it. As a matter of fact, he took pleasure using it. In my mind, I can cut a board with a hand saw about as fast.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
