Flu gas condensate
tonelow54
Member Posts: 4
in Gas Heating
Recently installed 5 in chimney liner that's venting 60,000 btu furnace and 40,000 hot water tank
Condensation is forming inside of liner and dripping into furnace should I insulate flu liner ?
Did you perform a combustion analysis? What type of furnace? Is the chimney on an outside wall?ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company1 -
It's a brand new ducane 80 percent furnace , did not do a combustion analysis due to the age , and chimney is in center of house0
Combustion analysis shouldve been done at start up with gas pressure test.....any more info you can give us will help....is there a chimney cap?go back perform a combustion analysis stack temp could be too low....gas press out of adjustment etcASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
thanks for the advice will do combustion analysis , and yes there is a chimney cap will update after performed0
Condensation can be caused by replacing an older boiler or forced air furnace with one that is more efficient. Wringing additional heat out of the combustion process reduces the flue temperature. But, if your new unit is 80% efficiency, that doesn't seem to be the likely cause. Can you link us to the manufacturer's specs for your model?
It's possible that the excess air is off - but a combustion analysis would tell.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
