DIY heat transfer paste for sensors
billyboy
Member Posts: 152
I thought most heatsink compounds were silicone grease and zinc oxide?
Yes, but
ZnO (zinc oxide) conducts heat only about 13% +- as well as copper
http://www.ncbi.nlm.nih.gov/pmc/articles/PMC4772549/
"We found the thermal conductivity values of pure w-ZnO to be 44 W/mK and 62 W/mK along the [1000] and [0001] directions, respectively."
Copper is listed at 401W/mK at other sources.0 -
The key to good thermal conductivity is excluding any air gaps, beyond that it's a matter of the uniformity of the transfer medium. Particulate size has to be small and uniform.
3PSI gauge0
