DIY heat transfer paste for sensors
  • ChrisJ
    ChrisJ Member Posts: 16,898
    I thought most heatsink compounds were silicone grease and zinc oxide?
  • JeffM
    JeffM Member Posts: 182
    All the compounds that I have seen are white, which suggests zinc oxide to me.
    wyo
  • billyboy
    billyboy Member Posts: 152
    Yes, but
    ZnO (zinc oxide) conducts heat only about 13% +- as well as copper
    http://www.ncbi.nlm.nih.gov/pmc/articles/PMC4772549/
    "We found the thermal conductivity values of pure w-ZnO to be 44 W/mK and 62 W/mK along the [1000] and [0001] directions, respectively."
    Copper is listed at 401W/mK at other sources.
  • BobC
    BobC Member Posts: 5,526
    The key to good thermal conductivity is excluding any air gaps, beyond that it's a matter of the uniformity of the transfer medium. Particulate size has to be small and uniform.
    Bob
    3PSI gauge
