Caleffi TwistFlow Manifolds and Viega FostaPex
johntrhodes81
Member Posts: 53
I was told by a supplier that Viega FostaPex can't be used with Caleffi TwistFlow manifolds. Does this sound right?
Manifold: http://www.supplyhouse.com/Caleffi-6686H5S1A-1-TwistFlow-Manifold-8-Outlets
Pex Fitting: http://www.supplyhouse.com/Caleffi-680504A-1-2-PEX-Fitting-for-Manifolds
John
John
I checked with Caleffi directly, they said it is compatible.0
Sounds exactly right . Supplier does not sell Caleffi manifolds so just says something to get the manifolds he stocks purchased from him or has just basic product knowledge and is not able to mix and match . Funny , my Caleffi flush cart is plumbed with FostaPex , go figureYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
How do like the flush cart? Good investment?Steve Minnich0
Completely happy with that purchase Stephen . Good idea Kurt , I think I'll do that also . We added a through fitting into the bottom of the tank to add water by turning on a valve when it is a bit too smallYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
The challenge with FostaPex is the tool that strips the aluminum jacket off does not go deep enough. So the nut and ferrule will not go on far enough to get a tight grip.
If you can strip a bit deeper it will work.
I drilled another hole in the blade of the stripper tool to deepen that jacket peel.
If you are using the Viega Fostapex tubing why are you not using their manifolds?0
caleffi manifolds have more features for similar price point.0
What does the Caleffi manifold have that the Viega manifold does not have?0
Here are some of the features on the Caleffi S-1, available up to 13 ports.
The TwistTop actuator may be unique in the industry. When you manually lock it open, it "makes" the end switch, nice for purging, checking wiring, and troubleshooting.Bob "hot rod" Rohr
Wish they came in Stainless also Bob .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
What about composite? We manufacture these, limited to 140°, so we have been reluctant to bring them to the US market.Rich said:Wish they came in Stainless also Bob .
Thanks for the info Hot Rod I work in outside sales for F W Webb in Allentown PA and we sell both Caleffi and Viega radiant pex tubing including the fostapex product. I have the fostapex tubing in my house running from condensing boiler to cast iron radiators. The fostapex is a great tubing. Please email me as much info on the Caleffi radiant headers including the composite models. Robert.eck@fwwebb.com thanks.0
Just a heads up, some of the pex manufacturers suggest using any fitting other than their brand may void warranty?
Not sure why if the fitting and tube have the standard listed. I suspect Sioux Chief builds most of the copper barb and crimp rings for tube manufacturers?
We have been supplying that composite manifold to the western Canadian market to get some feedback. They seem to embrace designs below 140F up there.
