Pipe Banging immediately after shut down
JohnW2
Member Posts: 21
We have a Bryant boiler from the 1980s and a one pipe steam system. The system has always been pretty quiet. However, the past few days it has developed banging in the pipes, but right after the system shuts down. As soon as you hear the thermostat kick off, it sounds like someone takes a hammer and bangs on the pipes for about 10 seconds. I thought pipe banging was a problem that occurred while the system was running. Any ideas? Thanks.
Go through this list and see if anything applies.
https://heatinghelp.com/systems-help-center/water-hammer-in-steam-heating-systems/
Linhardts Field Guide to Steam Heating has a good troubleshooting chart on pg 122, I have attached a copy -
3PSI gauge0
