Insulation to use behind recessed sunrads?
Jim45
Member Posts: 5
I need to put some insulation behind my sunrads which are recessed into the wall. There was no insulation put in when my contractor installed these several years ago. I've heard there is foil backed insulation I should use. Would someone be able to send me a link so I can do this as a DIY project and buy the right stuff? I assume I can get it a Home Depot?
Go to your local plumbing supply that sells the sunrads they should have it in stockASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Hmm. Honestly, I 've never seen Sunrads in plumbing stories. Only baseboard is stocked every store I've been too. Sunrads are sold direct from the manufacturer. I suppose this isn't an obvious question? Any takers?0
How much room do you have?
If you can get 1/2" poly iso board in back I would use that.
It is usually foil faced.0 -
thanks Kcopp. I can pull them out as much as i need to. They are fully recessed now. can the radiator touch the board? so it's flush against it? could I go to inch for more insulation? Is this the right stuff? https://www.insulation4us.com/thermasheath-3-r-3-2-1-2-in-x-4ft-x-8ft-polyiso-rigid-foam-insulation-board.html?gclid=CKvqw_bjzcsCFVg6gQodQ44Hig
Thanks for the help.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
