Taco PRV leaking
LionA29
Member Posts: 255
Found my Taco PRV 334 dripping throgh the threaded port at the bottom. Any fix or recommendation of a better replacement?
Thank you
Thank you
http://www.taco-hvac.com/products/hydronic_accessories/pressure_valves/boilerfeed_backflow/index.html
http://www.taco-hvac.com/uploads/FileLibrary/102-107.pdf
Don't forget a backflow device .
Maybe just a new 334 .
http://www.taco-hvac.com/products/hydronic_accessories/pressure_valves/boiler_feed_valves/index.html
732-751-1560
Rich McGrath 732-581-38331 -
Any brand will drip if there is a pressure issue. Check that first. Is the expansion tank full?LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com0 -
@4Johnpipe Do I remove tank to check if full of water?0
Yes...remove tank if its filled with water purchase a new one....if its not check the pressure in tank with a tire pressure gauge. ...it should be exact to your system fill pressure. If you get a new tank also check the pressure in tank sometimes there isnt enough...they come pre-charged at 12 psi....if your system requires a higher pressure use a bicycle pump to increase the pressure in the expansion tankASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company2 -
@Paul S checked tank and it's not full. System off and Pressure in tank is 22PSI.( hydronic heating use for basement only)0
Make sure you check the tank pressure while it is disconnected / separated or depressurized and room temperature.LANGAN'S PLUMBING & HEATING LLC
732-751-1560
