Trinity tft boilers
Paul S_3
Member Posts: 1,291
Has anyone installed these boilers? Want to know pros and cons.....says a turndown ratio of 8 to 1...want to know if they are any good....
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
Paul,
I have a few out there, and they are really good. I love the control, it is really easy to use and intuitive. I haven't had a failure yet but it is early on. If you have a wholesaler who is stocking parts you won't be disappointed. I love the that supply and return come off the top and bottom and the gas line as well for that matter. Worth trying.Tom
Montpelier Vt0 -
it says 8:1 turndown ratio on the brochure...but the minimum firing rate on the smallest boiler 60k is 17k btus....it would still short cycle if my smallest zones call without using a buffer.....the turn down ratio is what sold me at first....I too like the top or bottom choices for the supply and return and love the heat exchanger....overall I like the boiler and will start using themASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
My oldest one is 4 years old now and it works great its on an old gravity system runs at 98% combustion efficiency most of the time. I did have a display go bad after 3 years but they sent me a new one free of charge.
