Combo condensate pump/acid nuetralizer
Mad Dog_2
Member Posts: 8,413
Hey kids! Can't remember what magazine or brand, but a few months ago, I recall seeing a unit that does both and I said...it's about time. ..gonna use one soon. I'm sure someone here will know exactly the model #...thanks in advance. Mad Dog
Little Giant tech support.....says it's not them...was I dreaming?? MD0
Is that it?
Steve Minnich0 -
That's it Steve! YOUR THE best Thank you. They make those macerating toilets too. Thanks again. MD1
Saniflo does one, but it's only rated to 100k, so what's the point. Maybe you could get 2 and divert through a tee.
BTW, anybody get their own ph neutralizing chips/gravel?0 -
I didn't see a rating anywhere on either their UK or US websites, it just says It can handle the water from a condensing boiler, HVAC or other condensing fixture. Every pic of it that I see is under a boiler. Beautiful concept0
Finally installed the Saniflo condensate pump with built in acid neutralizer...0 -
We use dolomite limestone 3/4- in our neutralizer tees we make, get them by the 100# bag for like 7 bucks from landscape supplier.0
We make our own nutrilizers with dolomite limestone. The factory units end being the 2 AM Xmas day service call for a blocked nutreliser. We use either Little Giant or Liberty condensate pumps.
Henry, what & where do you get the box to hold the limestone? I thought about making my own but thought better of it when I saw these Saniflo units. Mine comes with neutralizing material that is round in shape, maybe 1/4" round. You appear to be draining a large amount....1-1/2" PVC!?!? Mine is a single 85K but boiler with 3/4" PVC..... I highly doubt there will be a service call on Christmas.0
These are storage bins that we buy a large quantity at a dollar store. They are made in the USA by Quantum. We drill each end and use a tailpiece adaptor whose nylon sleeve is replaced by a foam washer. We have had blocked draincalls on boilers as small as 100K.
Nice setup, Henry. Who makes tailpiece adapters in gray?0
They are regular DWV tailpiece adapters0
Maybe a white balance thing. Is the box gray or white?0
Grey, DWV pvc plastic is grey here0
Aha!
thanks~0
- 167 Indoor-Air Quality
