What is this valve
sciprox
Member Posts: 14
Hi all
I currently own an apartment in a building built in the early 1900's. We currently have base board heating which is building controlled with no in unit thermostat. My unit in particular stays pretty warm and I was wondering if any knows what this valve does in my room. I have not touched it since I moved into the unit and do not know if this is bleeder valve or something to turn off the heat.
Apologies for my lack of knowledge and hoping for some insight.
http://s399968921.onlinehome.us/window/baseboard.jpg
Thanks for the reply. Here is the exact other side along with first side but a bit further out. As per hot water or steam I think it is steam but honestly not 100%. I will try to ask the super tomorrow but he may not know0
Hot water baseboard .....those are isolation valves....heating system not original to building if built in early 1900sASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company1 -
Thanks Paul!
Again apologies for my lack of knowledge. Can I turn the valve off to stop the heating or is that a big no no?0 -
Depending on type of system you have if its series baseboard, all baseboards connected with one pipe from boiler then back to boiler...then no....by the looks of 2 isolation valves with bleeder it could be a monoflo system then yesASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Thanks for the insight Paul truly appreciated0
Thanks jughne, I will check look into this. I am concerned with causing any water leakage into the apartment below me. That be very bad for me and lead to some unhappy neighbors.0
Sorry to bring up an reply to this topic. I was able to shut off the valve in the bedroom.
However in the living room I have a similar setup as above except on one wall it has the white valve and the baseboard extending the entire length at which point the pipe disappears into the floor with no valves. The other wall has the pipe coming back up through the floor with no valves and the far end of that pipe has the bleeder valve with the same blue valve.
Apologies if this sounds confusing but it is basically the same setup as the bedroom except the valves are split between each wall.
The exception on this wall is I am unable to close the white valve. It just won't budge. Any suggestions? Still a bit nervous about leaking to the downstairs apartment.0 -
Either one of those valves would probably slow down the water flow. Most BB heaters like that have a damper on the top that is hinged to open and close. From your pictures it looks like there is one angled at the top of the unit.....the long white strip about 2" wide.....it is probably stuck but you may get it worked loose. It slows the air flow down somewhat like the tin foil would. it may be enough for comfort.0
Thanks. After some prying I was at to close the flap.
Is it still worth wrapping in tin foil?0 -
I have officially double wrapped in aluminum foil. Hopefully this helps.
I called a plumber who knows the building. He said when he came last for repairs he noticed that the boiler doesn't have an accurately working heater timer and is missing check valves.
He also said the system is a monoflo and my valve is frozen open.0 -
We do NOT discuss pricing on this forum. It says so right at the top of the page, in case there's any confusion.All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
