COLD Mudroom with heat source
saushah
Member Posts: 3
I have 6'*8' mudroom between Garage and kitchen, it has another door going to backyard. This room do have a heat vent. This room feels very cold, I thought this was due to lack of insulation , upon checking found out that all exterior walls do have an insulation. Not sure what could be a problem, any help/suggestion is appreciated.
Thanks
S
Thanks
S
The problem has to do with the fact that it is an outlying appendage to the heating system. It is not individually controlled, so the only way it gets heat is if the thermostat, which is located in the core of the home is calling for heat. Moving the thermostat into the porch will cause the balance of the home to over heat. Go hydronics and you can then put that room on to it's own thermostat and zone.
ME-1 -
Is this hot air heat or Hot water heat?
That is an entryway.
You need a lot more heat out there than your average room.
What is under the room? Does it have a foundation? Or open to the air?0 -
Is the floor concrete? It could have been originally a breeze way and was never intended to have been heated. Is the heat vent in the floor or wall?0
If it is forced air heat, is there a return duct?Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0 -
yes, forced heat vent is part of entire home heating system0
vent is in floor and floor is tiled , underneath concrete floor.0
The vent is probably not large enough to heat the area.
You have a cold partition (the garage wall) and two outside walls... that a lot of heatloss.
You could try this to push some more heat out there.
http://www.fieldcontrols.com/air-boosters?page_id=117
Short of installing a space heater out there.0 -
The question is how much heat would you like out there, and how much are you willing to spend to install and run additional heat. It sounds like a room with a high heat load with exterior walls and doors?
First step is to check all the weather stripping and insulation details. Make the room as efficient as possible then look at an additional heat source. Maybe a small electric panel radiator, possibly on a setback type thermostat.Bob "hot rod" Rohr
Living the hydronic dream0
- 120 Geothermal
