Can undersized system cause excessive makeup water?
Oh I wish you lived in Columbus, Ohio.0
I believe they will be fine as long as they keep leaks to a minimum, watch their PH and use Steamaster.Hatterasguy said:The problem with the "goodwill" rebate toward a new boiler is the fact that you have to buy another boiler with the name "Burnham" on the front. Again, we find that US Boiler won't stand by their warranty. No real surprise there.
Now, just where to you think you'll be in another 10 years or less after spending many thousands of dollars to replace that boiler?
Do you really believe that US Boiler is building a significantly better product than the one you have?
Probably get 20-30 years out of a crappy IN series.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Train the children to look after it also.
Many of my customers were once babies when I started servicing their parents equipment.0
