Flange Union
LionA29
Member Posts: 254
What is the best Flange Union to use on Drop Header? Looking for one that doesn't use gasket. In the attached pic, does that use a gasket?
Any input is appreciated, thank you.
In the pics, those flange used gasket?
Thanks0 -
I use regular unions, flanged companion unions and cast iron flanged unions they all work great. Just like @Paul48 mentioned the flanged unions use high temp gaskets and they work perfectly fine1
