Flange Union
LionA29
LionA29 Member Posts: 254
What is the best Flange Union to use on Drop Header? Looking for one that doesn't use gasket. In the attached pic, does that use a gasket?
Any input is appreciated, thank you.
  • Paul48
    Paul48 Member Posts: 4,469
    There's flanges, then there's unions. Flanges use gaskets, unions rely on a ground joint that forms the seal. You picture shows flanges.
    LionA29
  • LionA29
    In the pics, those flange used gasket?
    Thanks
  • Paul48
    Those are pipe flanges, and they use gaskets.
    LionA29
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,580
    JStar here recommends using unions, or flange joints only on the vertical pipes, to avoid possible leaks. As well as that, a union placed above the boiler on the riser, will make it easier in many years to replace the boiler.--NBC
    LionA29bmwpowere36m3
  • EzzyT
    EzzyT Member Posts: 1,379
    I use regular unions, flanged companion unions and cast iron flanged unions they all work great. Just like @Paul48 mentioned the flanged unions use high temp gaskets and they work perfectly fine
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    LionA29
