Centrotherm InnoFlue Q's
Steve Minnich
Member Posts: 2,868
I was just looking through their product catalog and really like what I see. Does one of their appliance adapters work on Lochinvar's WHN and KHN product line? Without the use of glue at the boiler connection? I'll switch from CPVC venting to that right now if they do. Throw in one of their test port fittings and I'll be good to go.
Steve Minnich
Yes they do Stephen. In there OEM book they have all the boiler manufactures models and state which adapters to use. That's all I use is polypropylene for venting both on the exhaust and air intake. It's a piece a cake to work with.2
Cool. So I took a look at the two exhaust fittings for the Lochinvar WHN and it looks like the first one would be glued which is ok because the second one wouldn't be "locked down". That's what I'm trying to avoid.Steve Minnich0
Do pick up yourself the gasket lube that Centrotherm sells, it helps getting the pipe and fittings together.1
Will do.Steve Minnich0
